PuffTheMagicDragon
Ive marked the pointed end of the switches to make it clearer
That's what I'll do on my next visit to the boat. Thanks.
This is the same as the ones I bought ( several years ago) at 2 for £5 from Maplin . Only things lacking are an audible continuity check and AC current other wise perfectly satisfactory and would buy again
http://www.toolstation.com/shop/Ele...t+Equipment/sd3348/Digital+Multi+Meter/p11867
Yes, I'm sure it's a multimeter I want.Are you sure a multi meter is what you need? for simple circuit diagnosis a continuity tester that puts a load on the circuit is probably more useful, a multi meter can mislead by showing voltage present when the circuit is unable to draw much current. Something like the one in the link is more than adequate. http://www.amazon.co.uk/Sealey-PP1-Auto-Probe-6-24V/dp/B000RA17CS/ref=sr_1_11?ie=UTF8&qid=1422963978&sr=8-11&keywords=circuit+tester
If the person does not understand the difference between voltage and current they should not be playing around with it. They should employ an electrician who does understand.
I understand the difference between sugar and salt, but that would not stop me putting the wrong stuff in my tea if they were in similar containers.
I intended to buy a multimeter on Amazon today, and discovered that there are dozens of models available ranging in price from £2.79 to £179.00. Somewhere in there is the one I need.
Can anyone advise on the best type/model to buy please? I only require it for boat maintenance.
I bet you are totally confused by now![]()
The clamp amp meter should be really good. However you will note the ranges for DC are 0 to 490 amps or 0 to 400 amps. So not much good for checking small or leakage currents.
I agree that for very low currents it isn't perfect but from 100mA upwards it agrees very well with the Adverc monitor / shunt setup on board
