RichardS
N/A
Some zombie threads have at least some rationale for being revived ..... but others, like this one, are a mystery.
Richard
Richard
Let's develop it.Some zombie threads have at least some rationale for being revived ..... but others, like this one, are a mystery.
Richard
For tight-arsedness, that would take some beating!Let's develop it.![]()
Is anyone as tight arsed as me and grind bits of old hacksaw blades to use in a jigsaw?![]()
Another very useful tool, but for different uses. I've never seen anyone using one to cut wood. Heavy duty sanding, yes, but I reckon the risk of a wood cutting blade jamming with painful/A&E consequences is just too highno one's mentioned an angle grinder yet! Ive got a mini 12v cordless from Bosch. It's brilliant. Small enough to get into tight corners. Powerful enough to slice through anchor chain and will cut a dead straight line in anything on the boat.
... and the mess!Another very useful tool, but for different uses. I've never seen anyone using one to cut wood. Heavy duty sanding, yes, but I reckon the risk of a wood cutting blade jamming with painful/A&E consequences is just too high
I've been fixing up my 40 year old boat for nine years and living onboard for three. I do work on her most weeks and the tool I use most often after the battery drill is my 8 years old Bosch multitool. It gets used mostly for hacking out fittings, cutting out straight shapes in wood or grp and grinding small areas of grp ready for glueing. It gets used occasionally for sanding and polishing too, and with a blunt blade for scraping off old glue and foam. What its no good at is cutting straight lines much longer than the widest blade. I have a battery jigsaw on board but can't cut a dead straight line with it, even using a guide. My handsaw makes a much better job, though a circular saw would make an even better job, but with rougher edges in my experience (wrong blade, probably). A router, even better still on a workbench with space for guides and fences.
I had one of thise Exacto style mini-circular saws. It did a good job of cutting ply (and ceramic tiles and metal when I had a house) but, like the circular saw and angle grinder, didn't make the cut when fitting out my toolkit to take on the boat.
I've installed a deck hatch using Sikaflex and it is leaking. Obviously I'm going to have to remove it and install it properly.
Guess what tool I will use to remove it??
Sorry Paul I must disagree as an adze is a traditional boat building tool
Native Alaskan boat builder
As used in Rye Shipyard- the Construction of Motor Fishing Vessels, Rye, Sussex, England, UK, 1944
I bought a mini Li-Ion grnder from Aldi or Lidl a while back, they were selling wood cutting blades for it. I bought some but haven't tried them. I feel that whatever discs are in it, this thing has more A&E potential than any mains angle grinder I've used.Another very useful tool, but for different uses. I've never seen anyone using one to cut wood. Heavy duty sanding, yes, but I reckon the risk of a wood cutting blade jamming with painful/A&E consequences is just too high
I thought I was frugal but don't stoop that low. I've considered modifying a used blade to extend its life. They always wear out at the same place.Let's develop it.
