Boo2
Hi,
I have inheirited 3 bilge pumps in my boat and there are some problems. 2 of the pumps are electrical (Rule 500/800 types) and one is mechanical. There is only one discharge fitting, high up on the transom.
There are some problems with the electrical connections which I intend to fix by means of glue heat shrink and heat shrink terminals but there is also an as yet undiagnosed problem with the Henderson Mk5 manual pump does not pump at full capacity.
My question is, how should all these pumps be connected up ? I intend to replace the electric pumps with higher capacity versions at a later date but in the interim I need to know what the ideal setup should be ? Is it acceptable for the electric pumps to be plumbed in series with the manual one (I presume not) ? Otherwise there will need to be some kind of outlet manifold, but how do I ensure that operating eg the manual pump doesn't back flush the electric ones ?
Anyone know a website where all this is explained, or care to attempt it here ?
Thanks,
Boo2
Thanks,
Boo2
