channel
Thats what I thought initially but it doesnt work like that.or so I am told.
The mud is silt from the Estuary settling in the harbours, very little mud comes down the rivers.I havent noticed any appreciable changes to depths since the bay was impounded. I imagine the silty water brought in through the locks would mostly get sucked back out through the sluices.
You can sluice between locks at Cardiff Barrage - used when the sea level is higher than the bay level (4.5m od). This minimises salt water contamination of the Bay's fresh water and also limits the possibility of siltation inside the Bay. Outside the locks is a 'settling area' for salt water which can then be sluiced out also.
Much of the time the local ports operate in the same manner - ie keep the mud out. From time to time when both gates are open at high water or estuary water is pumped in to increase dock levels mud is introduced and dredging becomes a requirement.
