Jokani
I am not 100% on how to check if there is sufficient oil in my MS2B gearbox.
The user manual has a different dipstick design to mine (pictured) if I don't screw it down (as per manual), it hangs on the pin and measurement would not be precise.
If it is not down/screwed in, then the oil on the minimum level marker, screwed it in is on the upper level marker.
I'm guessing that the dipstick needs to be all the way down, but I will worry about it if I am not 100% sure. I am hoping someone can give me a definitive answer as to which is correct.
