sailorman
Its 16 yrs since i measured mineSMEV too wide, see OP.
Origo works darned well but Mrs K wants a grill and a fast oven.
The width is going to be the deciding factor. Cooker dimensions are often rather vague; you need to check the overall width including gimbals, which usually add 35mm or so to the declared cooker width.
For what it's worth (and I'm not on commission) the Nelson must be on the narrower side. I know this because I had to build up some spacer blocks when fitting it into the gap left by the previous cooker.
Can I suggest you make provision for refillable bottes to save the rip off charges of Calor and Camping Gaz
You CAN refill at petrol stations in most countries and save an arm and a leg.
Look at Gaslow and Google others.
If the OP needs Calor bottles he might PM me
...don't forget you'll need an Annex M regulator not a normal one.
Hi
Tony plotter here!
It's really worthwhile
Are you planning a blog and how's the daily budget looking?
Fair winds
Tony
I have an lpg car. The tank has a float in it that shuts off the inlet to limit the amount of liquid. Ie to leave the right amount of (compressible) gas above. If you remember you SVP the pressure in the tank remains constant as the liquid rises and the gas reduces. With no shut off, a portable bottle will overfill, no gas to compress and bang when it warms up. Dont do it!
I presume the "refillable" ones have the shut off? As the petrol station attendants wont be able to tell the difference the ban is understandable.
No gas on my boat. A diesel hob, and a £100 stainless oven/micro/grill. Powered by shorepower or an inverter.
Gas is a pain, expensive and stops working when its cold. Plus you have to be careful with it.
Yes, the Gaslow refillable bottles have a float that shuts the supply off when 80% (I think) full. They are big bottles though, not something I would like to be carrying on and off a boat, even if I could get them filled somewhere.
No pain at all in my gas installation. A Camping Gas bottle lasts us around a month, Eurocamp ones quite a lot longer, living on board and cooking most nights. Even at £20 per bottle that's not bad but at €6.60 per bottle it's a bargain.
To add to Vyv's refutation of Elessar's points - only butane stops vapourising, propane is good for -12C, most LPG bottles are a mix of both.
My 3rd hand experience of diesel stoves is that they're hell to cook on, make a smell and are prohibitively expensive. Like Vyv, I find one Camping Gaz bottle, cooking one meal a day, lasts 30-35 days. Exchange bottles can be expensive - in Italy as much as €18, but refills work out @ €6 - €6.50.
Still horses for courses and we all cling tight to our prejudices - even Origo fans!!
OP said:Gas bottles will be in a locker on the aft deck, plumbed through the aft deck and then the engine room
When designing the solution make sure you get the right parts and fittings.
Regulators and valves come in more types, straight/angled, with gauge or not etc. Might challenge the space available.
PS! The bottle locker must drain outside the boat, not into the engine- or any other room.
+1 for the bubble leak detector.
+1 for the Nelson Spinflo... Great stove, and it does proper toast too !!
+1 to all of that, and i would add a gas alarm in the bilge too.
If you are struggling to find somewhere for a safe gas locker with overboard drain, on some boats the anchor locker is a quick and easy solution.
