Delfini
I have a 240V Sterling marine twin output 12v battery charger located underneath the cockpit and each of the twin outputs connected to either the 3 x domestic batteries or 1 x crank battery bank/s - I plan on installing my new 2 x 100w solar panels through a Victron MPPT controller installed next to the Sterling on a ply bulkhead
Given the MPPT has only 1 x 12v output can I connect the output to both of the 2 x outputs on the Sterling to save running wires in parallel to the existing twin charging cables) or will this cause the Sterling a problem when trying to decide if domestics or cranking battery have reached full charge ?
I plan to isolate the solar when charging the batteries from 240v and alternator charging of both banks is via a VSR relay - not sure if thats relevant ?
Thanks for any advice
