burgundyben
You will probably find that the centre of gravity of that arrangement is round about the engine back foot. A problem if on flexible mounts.
I had a four cylinder Ford Sabre with PRM box, on flexible feet, and the whole thing rotated about the after mount. I also had a raft extending a frame forward for hydraulics, I wish I had extended it aft to have a mount level with the coupling, (or even six mounts) to dampen the vibration.
I should have realised at the start, when the engine arrived, gearbox attached, I could rock it back and forth on the rear foot.
Yes. You are quite right. The flywheel is a big lump and it's right where the rear feet are. Plus the box hanging out the back.
I'll need new mounts, the old ones were replaced in 2015 but are shot already.
I'll call R&D marine before I order. I suspect a different mount at the rear. They will need to be shear mounts as there's no python drive or similar.
