MOST EFFECTIVE SOLAR PANELS
Scotty,
Depends on which type of cell you go for. There are two basic types - Crystalline and Amorphis.
Crystalline:
Cells are manufactured from thin slices of silicone
Available as Mono or Polycrystalline (not much in terms of performance between them)
Better output for a given area
Last for 10-20 years
Can be bought framed or as a semi flexible for bonding to the deck
More expensive
Amorphis
Cells are manufactured from powdered crystalline and sprayed onto a glass or plastic substrate
Provide more output in low light conditions than crystalline
Much larger area needed than crystalline to provide the same output (eg less effecient in bright light conditions)
Cheaper
Last 5+ years
Can be bought in solid panel or roll up flexible
Unless you want the hassle of unrolling/rolling panels all the time or having a gantry with panels fitted to it, the best type are the semi flexible crystalline types that you bond/screw to the deck. They can be walked on etc.
Hope this helps
James
Just in case it's useful, we have had four flexible crystalline ones on deck (a cabin roof) for ten years now, they get walked on, but not a lot. Still all working fine.
