V1701
This might be of interest - I have a Trangia camping stove on board so thought I'd try it as a heater. It takes about half a cup of meths to fill the burner, results were as follows, pics below as well:
I had the stove on the cabin floor near the companionway and the thermometer at about chest height right at the other end of the cabin. Didn't modify the stove in any way, just used the frying pan lid which leaves a gap around the top of the stove (see pic). The burner ran out of fuel about 45 minutes in, so I reckon you'd get about an hour or so if you set it off on half heat.
I was surprised how much heat it gave out and how quickly it heated up the cabin. Size of cabin is about 8' x 6' x 6' (Albin Vega), hatch was left open a few inches for ventilation. I'd say a reasonable means of having heat for occasional use if I didn't have shore power available (normally use oil-filled radiator). The stoves are from £50 odd new, lots of used ones on ebay, you can use them secured to a gas stove if you run out of gas and also good to use in the cockpit - they're designed for use in windy conditions. I'll try it again in colder conditions & with a CO detector...
Pics:
- Initial cabin temperature was 16.4c
- 15 minutes in on full heat reached 19.8c, then put it on half heat
- 20 minutes in 22.8 degrees and that's where the temperature stayed on half heat
Pics:
