RIN
Further to my recent post about vdo rudder indicator problems,
http://www.ybw.com/forums/showthread.php?456515-help-with-siemens-VDO-rudder-sender
I have traced all the wiring and found that there is no 12v+ at the upper helm indicator. In fact a dedicated upper helm vdo gauge had blown. I replaced it with a 5A fuse and this time a 7.5A fuse nearer to the battery blew. I replaced it with a 2A fuse and again the dedicated fuse blew.
After a bit of an investigation, it turns out the fuse blows when either engine is switched off.
I have also bought a new gauge and tried it in both helm positions so it's not the gauge unless two have developed the same fault which would be very unlikely.
What is going on? Can anyone help or suggest what I can check next?
Many thanks
Many thanks
