firstascent2002
Had to use this for the last ob fillup. Will it do any harm in the short term? Indeed, would it do any harm for long term use?
J
J
J
J
I want to take my Avon out tomorrow, I have just found some 2 stroke motor bike oil in my store but it says for use up to 50 -1 can I use it in my Evinrude 4 which is 100-1 or will it clog everything up? I am being mean but dont want to spend 12 quid on outboard oil if this will do!
Shouldn't do any harm, only (very minor) risk is a spark plug fouling up. That said I ran a Yamaha (100:1) on 50:1 fuel for ages without any problem.
Yoda
mix 100>1 & it will be ok but better engine longevity if used @ 50>1 or perhaps you have a "Special" additive for sale
Hi Sailor Man
Yes I have loads of additives for sale, in fact a shed full!
Nothing that says I can use old motor bike oil though.
Just a thought whilst we speak, as you are on Windermere, have you been up to Pull Wyke Bay at the Waterhead end the the Lake, there used to be a fantastic old converted lifeboat called LAURITA (London) which if it is still arround would be a great photo for your potfolio.
Buy you a pint in the Drunken Duck next time I visit my favourite place!
My little Suzuki 2 horse says 100:1 in the manual but then says that if you're using the motor "commercially", use 50:1. I've always inferred, as a result, that 50:1 (a) won'tdo a 100:1 outboard any harm and (b) is actually good for it! That said, a commercially used one probably won't get laid up for long periods, so I suppose washing out and not leaving fuel in the tank would be more important.
If 50:1 causes problems with the kind of running you do, maybe your plugs are knackered or opening them a touch may help.
Of course there is nothing to stop you using 60:1 or 70:1 (just a bit more tricky to calculate). It's still better than 100:1
I used some 50:1 in my 4 stroke mower the other day (it was all I had) Ran very well.
