richardbayle
What diameter line for mooring a 41 footer? Not a mobo!
I'm thinking 12mm.
I'm thinking 12mm.
14-16mm is easier to handle under tough conditions. 12mm perhaps a bit puny for the size of boat IMHO.
It really isn't the strength - any size you can comfortably handle is strong enough. The problem with thinner stuff is resistance to chafe.
Think of e.g. genoa sheets. You put huge loads on them with big fat winches and they take it. Mooring lines don't take anything like that sort of load, even in extreme conditions.
I would have thought that with most boats the cleats would pull out before the lines snap.
We are about the same size and use 18mm 3 stand nylon.
Get together with a few other owners and buy a 200mtr reel and cut it up
I'm thinking 12mm.
Don't you find that stuff (compared with multiplait) snags in fairleads and around cleats?
