lw395
One of my pet peeves that I have been ranting bout for years is that pendant failures are often incorrectly assigned to chock chafe when in fact many of them part due to anchor chafe from anchors left on bow rollers. Seeing as I live right near the local harbor which has over 1200 moored boats I have plenty of access to mooring failures.
Some of you who frequent the US sailing forums will remember my many rantings about folks leaving anchors on their bows, in exposed mooring fields, during rough weather. If your mooring field has the fetch to build waves that can pitch the bow of your boat then it is rather rude & inconsiderate to the boaters around you, who may get hit by your drifting boat to not remove your anchor when a blow is expected. Many times chafe comes from the chocks but after motoring around the anchorage the morning after this short storm I saw that most of the chafe was anchor related. This is not the first nor the last storm I have or will monitor for mooring failures.
For the rest of the article and a LOT more photos you can read it here:
Mooring Preparations & Precautions (LINK)
For some time now I had been trying to capture the "moment" on film to really drive the point home about REMOVING your anchor if a storm is coming. Some folks actually get it, but still many don't. I think this Island Packet is a PRIME example of "my anchors are protected by a bow sprit, I don't need to remove them" line of reasoning.
PLEASE, if not for your boat, think of the others around you and what your boat would do in 30+ knots drifting through an anchorage after the anchor has sliced through the pendants. I watched it happen in real time, it leaves a pit in your stomach. Thank god MOST moorings in Falmouth are dual pendant rigged. This boat owner came very close to owning a pile of off white fiberglass splinters..
That was always going to happen.
Looks fairly exposed, a bit like my old mooring.
A lot of people do not seem to appreciate how flat an angle the strop may go to in a blow, especially with some waves about.
The strop would have been well clear of those anchors in benign conditions.
It might have worked better with a much shorter strop.
Boats with bobstays are a bit problematic, it will always chafe.
Regarding 3 -strand warps unlaying, it's true I've got one in the garage somewhere. However I don't think the cure is to use different rope, but rather to get a swivel that works! Braided rope will be weakened by winding it up too! I have seen small cruisers end up very bow down due to winding up the whole mooring riser. I think the swivel is best placed between the buoy and the boat where it isn't corroding and can be inspected easily. Motorcycle aerosol chain wax is the stuff for lubing such swivels BTW!
