Moody 27 leaky window
Richard_H
31 May 2001
Following all the recent rain we have been enjoying I notice one of the windows on my Moody is leaking internally - may be a simple matter of reapplying mastic or sikaflex. Can anyone advise how to remove the windows and what type of sealing compound should be best used to reseal. The windows appear to be screwed in from the outside? Is the first method of approach eremove screws and then push?
Thanks in anticipation
Richard_H
You could try posting on the Moody Owners Website info area at
www.moodyowners.org.uk/infoexchange/
I would be inclined to try removing the sealant on the outside without removing the windows. I would replace with a rubber based sealant. It should do the trick.
good luck
