scotty123
Who, is trying to win?Buck you can't win against this guy ?
Just pointing out the error of your ways, befor someone gets hurt.
I would suggest that is not it. I am assuming you are referring to the harness on a line type rescue sling here.What exactly do they need to know in order to deploy a life sling and motor/sail in a circle with a self tacking jib?
1) how to open a Velcro flap and throw the contents over the side.
2) how to start the engine, put it in gear and take it out of gear
3) how to turn the wheel/tiller
that’s it.
Jaazus you never give up do you ?Who, is trying to win?
Nope, there's a man in the water.Jaazus you never give up do you ?
I well remember my YM examiner's comment "MoB is not an academic excercise".There's not...it's hypothetical.
Yes he's dead right.I well remember my YM examiner's comment "MoB is not an academic excercise".
No, we performed the drill as prescribed & recovered the casualty.Yes he's dead right.
I'm agreeing with you, can't you see thatNo, we performed the drill as prescribed & recovered the casualty.
I know.I'm agreeing with you, can't you see that
It wasn't a questionI know.
"Can't you see that" is.It wasn't a question
Clever little git ain't you. Don't reply"Can't you see that" is.
Yep & bloody irritating as well.Clever little git ain't you. Don't reply
Hahaha, I won't argue with you about that.Yep & bloody irritating as well.
If you harden your main sheet without adjusting the jib, what happens if you turn into wind and leave it there?I would suggest that is not it. I am assuming you are referring to the harness on a line type rescue sling here.
Just chucking the rescue harness over the side is only part of it. Firstly one has to get it to the MOB & tests have shown that it does not go straight to the centre of the circle but follows the boat because of the way the rope runs in the water It will take several circuits at least & for an experienced crew to do that takes practice.
Then even if the MOB does manage to catch the harness he/she has to get into it, or hold on whilst being pulled to the boat. Have you ever tried pulling a load on a silliy little 6mm line 25 metres long? I have ried it whilst doing safety boat duty in a RIB. It is not easy & often the RIB goes to the MOB rather than the MOB to the RIB so you get an idea of the pull. The yacht is probably bouncing along at 3 kts at the same time because the crew do not know how to stop it.
Regardless of letting all the sheets go, my boat ( which has a self tacking jib) does not just sit still. It goes off like a scalded cat every so often. It will not, for instance, heave too with an experienced skipper at the helm.
So--- with the greatest of respect-- I think you need to work out the practicalities of your ideas before you go too far
this is nothing to do with yacht master MOB recovery. I can do that, I've got a little blue book that confirms it.No, we performed the drill as prescribed & recovered the casualty.
I've tried this.I would suggest that is not it. I am assuming you are referring to the harness on a line type rescue sling here.
I just simply have no PLBs but tell the mostly inexperienced guests we sail with that only two things are guaranteed to kill them - the boom hitting their head and going overboard. So as we don’t encourage (but do allow) harnesses to be worn except in very rough or nighttime conditions it’s up to them to stay alive. Seems to work so far and although I am fairly sure I could get back to a MOB from being under sail, I am certain that my sailing partner of 33 years could not so my plan is to remain on board.I do not know what Cardiff Bay is like, but on the east coast I am based on the River Blackwater, (but there is the Orwell & Stour for some). I would either take an experienced sailor along, or at least stay in the river. There is plenty to do & see. No need to be a hero with beginners as it would probably only frighten them anyway.
I wear a PLB & carry 10 mini flares on the LJ. I would show the crew how to start the engine & use the radio at minimum. Instructions are on the back of the chart table lid. If I was separated I would just set off the PLB, Fire off flares every so often, ( hoping I did not drop any) & I know that there is a good chance the boat would run aground after a while so the crew would get help eventually. I could put the hand held VHF in my jacket if I wanted to.
In the river I could survive for a couple of hours- I know because I have spent hours in it whilst windsurfing & dinghy sailing. I would not expect to be taking beginners in early season in cold conditions. There is a good chance I might end up on a sandbank, I have in the past.
People watch the river & hopefully I should be seen eventually, as would a boat doing odd things.
