Jamie Dundee
Gone native then eh?In my defence….I’m easily confused
Then, as I said before, the MMSI in the radio is wrong and needs to be reprogrammed. The radio probably came from another vessel.Many thanks for the replies.. I'll check out Mars Itu and see if I can get any numbers to match. I'd like to get this sorted out DSC is an important asset.
Edit - I've actually already looked on Mars Itu which is showing the previous owner, the correct Call Sign but a completely different MMSI that doesn't match that of the onboard VHF..
Yeah I get that.. No it's actually the original radio for the boat. I have the full documentation including the original build and chatting to the broker etc who knows the history of the boat... It's definitely the original. Strange but true..Then, as I said before, the MMSI in the radio is wrong and needs to be reprogrammed. The radio probably came from another vessel.
Go back to Mars itu and search the mmsi from your vhf. This should give you the associated call sign.Yeah I get that.. No it's actually the original radio for the boat. I have the full documentation including the original build and chatting to the broker etc who knows the history of the boat... It's definitely the original. Strange but true..
Edit; looks like you tried that. Buy a new vhf and register the boat as previously unregistered. Keep the original vhf as a spare
As I say above, if you bought a french registered boat, it would probably have a French VHF licence.that’s not the rules! One MMSI for life or else!???
Thanks Mike, I didn’t know that. I’ve had my paperwork checked a couple of times by the Guardia as well.When you move a boat from one country to another you will need a new VHF licence thus a new MMSI number.
Thanks Jamie.. The problem with that one is that it's a dual handset Raymarine modular system so it's a lot of kit to make redundant over an MMSI number. Particularly since I recently soldered in a new Mic cable which took patience like no other..Go back to Mars itu and search the mmsi from your vhf. This should give you the associated call sign.
Sorry, I didn't make myself very clear.Thanks Mike, I didn’t know that. I’ve had my paperwork checked a couple of times by the Guardia as well.
It answers my query in #28 as well.
If you "Google around" you should find specialists that will reprogram the MMSI numbers.Thanks Jamie.. The problem with that one is that it's a dual handset Raymarine modular system so it's a lot of kit to make redundant over an MMSI number. Particularly since I recently soldered in a new Mic cable which took patience like no other..![]()
Many thanks.. I've had a chat with my very helpful broker, who just happens to be next door and also manages the yard work and he's given me a contact for Raymarine jobs.. Apparently the guy is a busy soul but should hopefully be able to do the bizz with the radio.If you "Google around" you should find specialists that will reprogram the MMSI numbers.
The VHF set manufacturers or their distributors/dealers will anyway.
You don't have to buy a new set.
Most rules have a little built in ‘flexibility’…..that’s not the rules! One MMSI for life or else!???
