Daverw
Halfords manage due to loop hole for car ac, this also has oil and dye in it which is often not compatible with the oil in your boat system. All R134a available now is recovered gas. You are correct that the handling regs are not universal between countries, this is the same for most certification, this is got round by most experience techs, as time served and proven competency then come into play, luckily I work mainly in industrial refrigeration which uses ammonia or CO2 which are a different level of certification due to high risk of death if you get it wrong.
The issue with servicing is the equipment needed for gas recovery, pressure testing and evacuation , if you look at the stuff a car garage uses and this is as basic as it comes, not easy to get it to your boat, I have a small vac pump which is quite power hungry and heavy, recovery unit which is about the size of a tool box, gas bottle, recovery bottle and bottle scales, don’t think I could keep all this on board. That’s why most who do this on the side don’t follow the rules
