single
I was thinking of adding stainless steel chain between the hawsehole and the anchor for cosmetic reasons and to stop rust marks.Would this cause any significant corrosion problem at the joins?
What sort of link are you proposing between the SS and galvanised chains to join them? It might prove to be the weakest link.
The corrosion issue is not that great between galvanised chain and stainless steel components. Usually it is confined to loss of a little zinc on the last few links of the chain.
When using C-links to join chain I suggest you look at the info on my website. There is an enormous difference between the good ones (Crosby) and some others. However, I'm not sure how good the galvanising is on any of them and there can be serious galvanic corrosion between chain and links in some cases. I know nothing about this one but it's a great example.
That would only be true if you were using the chain to hold the anchor (off the bottom, for example). If, on the other hand, you were using the anchor to hold the boat (as most people do), that link would have to transmit the full force involved, and if it broke you would not only lose your anchor but possibly your boat as well.I was thinking of a chain link? It not as if there is that much load on it that near the anchor.
