ducked
Here on a T piece which I THINK is intended to be used to flush the salteater cooling circuit by closing the seacock, and sticking the hose in a bucket of fresh water. Seems to be s mix of stainless steel pipe, steel compression fittings (quite rusty) and brass (domestic?) fittings, such as the valve. I suppose it would be worse if it all took salt water.
Ill clean it up somr.
Is there any suitable lube for the brass ball valve?
