Missing Yacht.
toyboy
17 Aug 2013
What am I missing here? There should be an outcry about the search being called off unless everyone knows something I do not understand? These are fit men who are supposed to be in a life raft so why is the search being called off?
It is a long way offshore and the US SAR only had a last GPS position, not an EPIRB or any other form of beacon. With 6 metre waves a liferaft would be particularly difficult to see even from only a cable away. May have more luck from the air but probably beyond helicopter range. The cost of mounting a SAR operation can often run into millions of US$. For instance the Tony Bullimore rescue in the Southern Ocean cost the Australian taxpayer in excess of one and a quarter million AUD. Sometimes a decision has to be made to not risk SAR personnel and resources on what must appear a fruitless search.
Blondie Hasler believed that anyone who goes ocean sailing should 'die like gentlemen' rather than put others lives at risk.
I think it likely they are in the life raft somewhere. They knew they were taking water, and could sink, so I am sure they would have prepared the life raft just in case - or am I being naive?
If so David & we all hope you are correct, my only reservation is that the raft is too big being a 12 man raft with 4 up. it will be prone to flipping over being lightly loaded. if it inflated inverted i doubt they could right it
The evidence of the PLBs does not point that way, I'm afraid.
As experienced yachtsmen they will know that and taken ballast, and lots of food
Such as?
I spoke to a guy some time ago, who had to abandon with his mate in North Atlantic. Their liferaft was way too big for just the 2 of them & they got tumbled by the wind for over 3 days. The 12 man, is as described, designed for 12 people, who are the ballast & even then, inversions can happen.
Hopefully, if 12 man, it wasn't stowed in a locker, which with approx 50kg +, would be a b.ugger to get out & deploy.
The BT Challenge yachts had 2 of these in a cockpit 'coffin' & even they were difficult to get out.
