Minor Gelocat Repair
capricorn
26 Jul 2004
Hi,
I have a couple of small chips in my deck that I need to fix. Nothing major but the gelcoat has been chipped exposing the laminate below. Chips only about 2 or 3 mm in diameter.
I spent half an hour gazing at the shelves in the chandlery trying to decide what products to buy to repair this. Came to the conclusion that a small pack of 2 pack epoxy in the "hand soap" type dispensers was the right thing for the job.
Is this what I need ? Any tips for carrying out this sort of minor repair ?
Apologies for the schoolboy question and thanks in advance.
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by capricorn on 03/08/2004 16:22 (server time).</FONT></P>
cameronke
31 Jan 2003
Clyde,Argyll, Scotland
Hello Capricorn
Though the epoxy would certainly do the job it is a bit overkill. Epoxy tends to be used below the waterline. you would also need to paint it as it finishes gray in colour.
There is a gel-coat filler product which finishes white in colour and so may not need further painting
Hope this helps
Cameron
<hr width=100% size=1>Work to live, live to sail
BrendanS
11 Jun 2002
Tesla in Space
<A target="_blank" HREF=http://www.ybw.com/cgi-bin/forums/showflat.pl?Cat=&Board=mby&Number=248744&part=1>click here</A> to see all you'll ever need to know about gelcoat repair
<hr width=100% size=1>Me transmitte sursum, caledoni
AlexL
24 Jan 2003
East Coast
I have used plastic padding gelcoat filler <A target="_blank" HREF=http://marinestore.co.uk/Merchant2/merchant.mvc?Screen=PROD&Product_Code=so-md35937&Category_Code=fillers> (Click here) </A> with great success - its basically white car body filler. mix up a small amount fill the hole and it sands really easily. I sanded to shape with 120 grit and then used a couple of grades of wet, wet and dry and then a bit of cutting / polishing compound. You Only need to sand in total for a couple of minutes to get a really good finish.
