RichardS
N/A
We've enjoyed many threads over the years focusing on the mineral/semi-synthetic/synthetic oil debate and my view has always been that modern fully synthetic oils are preferable to any other oil.
However, until recently, I have used semi-synthetic oil in older engines like classic cars and the boat because they usually require higher viscosity oils at the "hotter/summer" end of the scale such as 40 or 50 weight and such synthetic oils have been difficult to obtain and/or expensive. Those days seem to be over and I am now running my classic cars on 20W-50 synthetic and my boat on 15W-40 synthetic.
I was recently discussing oil viscosity specs with my Son as I sometimes ring the changes with modern engines although using gut-feel about what might be acceptable based on the manufacturers specs which usually show large amounts of overlap at different notional ambient temperatures, and he pointed out the following which I think is an interesting way of looking at it.
Imagine an engine where the ambient temperature recommendation, say 0 - 30 degrees for the UK, is the common oil of 10W-30 spec.
Now, that oil starts off on a winter's morning at viscosity 10W, but as it warms up it thins and goes to viscosity 5W and then viscosity 0W so 0W-30 and 5W-30 are both within the range of viscosity that the engine actually sees, even when you start off with 10W-30. However, the engine will never normally have to work with a cold viscosity of 15W so going high at the W end is not the best idea.
Similarly, at the other end of the scale, the oil which is at 30 at engine temperature will have previously been at 50 before it drops to 40 and eventually, when the engine is up to temperature drops to 30. However, the engine will never normally have to work with a hot viscosity of 20 so going low at the "hot" end is not the best idea either.
In summary, in this example, going down to a 0W / 5W or up to a 40 / 50 is still going to be within the range of what your engine operates under so if you can't get exactly what is recommended at the right price, then going low at the cold end or high at the hot end is not going to cause a problem, although the closer to recommended, the better.
Richard
Richard
