Mildew - boring but good!
longjohnsilver
30 May 2001
Do you suffer from mildew, mould a problem down below.
Well I've discovered a miracle cure, forget miltons, try Dettox mould and mildew remover, comes in a handy spray bottle and does exactly what it says on the bottle. So far it's completely removed mildew from diving equipment, a cushion and curtains without any other nasty side effects.
Would not have believed it if I hadn't seen it with my own eyes. Absolutely brilliant!
pvb
UK East Coast
Er...
Dettox Mould & Mildew Remover is actually bleach, but very expensively and attractively packaged! I don't doubt that you've had good results with it, but you could have done the same with a mild solution of household bleach.
Anyone with a serious mould/mildew problem might consider Polycell 3-in-1 Mould Killer (about £5 per litre from B&Q) which contains a couple of very good fungicides and has no bleaching effect. I use it on my canvas sprayhood and teak decks.
VMALLOWS
9 Oct 2001
Emsworth, Chichester Harbour, UK
I can't verify (its down on the boat) but I'm pretty sure that DETTOX is just bleach solution with surfactants. It works, but so does bleach at 9p/litre. (you can always refill the sprayer, but get the dillution right). Some of the other 'Mould Remover & Prevention' cleaners use a completely different chemical and while similar at removing the mould do seem to keep it at bay for quite a time (eg 6 months).
Any chemists care to comment?
hlb
RIP
Any Pub Lancashire or Wales
Well thats you soon blown out the water John. Better stick with MBY with all the nutters. /forums/images/icons/laugh.gif
<font color=blue> Haydn
AOWYN
28 Dec 2002
www.clinksystems.com
Re: Mildew -on foam-backed vinyl!
Whichever you use, if you have black mildew spots on foam-backed vinyl lining, don't let an enthusisatic helper go spraying and scrubbing. The quickest way I know of to ensure that aging foam backing crumbles and gives up is to try a vigorous clean of the vinyl.
longjohnsilver
30 May 2001
Looks like it Haydn, but still haven't found anything better which axshully works without fading the materials, suspect it's more than just watered down bleach.
