Micro PC vs laptop?
We're primarily navigating on an industrial waterproof Android tablet from Samsung. We do have Signal K running on a Raspberry Pi with a waterproof enclosure. Ours was a bit more DIY, but now you can get quite nice marine setups for RPi. For example:
HALPI2 Computer
Agree with all/most this but my old mini pc was 12v. No need for voltage adaptor. Why do you think a usb power input is good?
My NAS is also 12v but I daren't run it directly off the battery as I'm afraid the 13v or 14v would kill it. Currently running off the inverter, but I guess there are DC-DC voltage regulators so I may try one of those in future.
Get a little Victron DC-DC charger, i use them for 3 different 12V circuits. Don't use cheap and nasty ones for something expensive. But, if the inverter is on anyway, the power saving would be negligible.
HALPI2 Computer
Nice box! My RPi 5 with MacArthur hat was a nightmare to fit into a box. Short flexible cables were near impossible to locate.
Obviously, there are a range of lap tops as well. I recently up-sized from the company micro-lap top to a more powerful one. Not much bigger and a lot faster, more memory etc. The trend towards tiny, lightweight laptops has a downside. For example, my eyes aren't getting better and my fingers have not gotten smaller. At home, I plug it into a keyboard, screen etc., and it runs about like my home PC (not micro).
Get the lap top you need, keep a keyboard on the boat, and you should be good. Add big screen access if you like. I used to do a good bit of engineering work and writing from the boat, and that set-up worked fine. Honestly, the Ah were not enough to add up.
If you have a nav station, a mini computer can be hidden away very easily. With a flat screen fixed to the bulkhead with industrial velcro, full size wireless keyboard and mouse, you have a grown up system that is safe at sea, easy to use and takes up minimal room.
I went this way after a laptop as it was hard to secure the laptop at sea and I needed to run it from 220v. It didn't like a direct DC supply.
The mini PC was also inexpensive
I'm leaning away from the idea of fitting a screen at the nav station. The chart table is 75cm deep so the screen would need to be bigger than the available bulkhead space. There's also a really high fiddle on the chart table which would make using a keyboard annoying. And the seat isn't very comfy either.
On the hunt for a vertical sliding monitor/TV mount so that the screen can come up from inside the saloon table. Bonus points if it's motorised 😂
