oldbilbo
Just look at what the OP started! They'll be hidden inside/under the 40 y.o. boom, with reefing lines secured to them.
Scroll down to the graphs and follow the as welded line
http://egmrs.powweb.com/EJS/PDF/vo282/325.pdf
I'm sure there are others
I see that I am incorrect. I still don't understand why it should happen, as the weld is by definition in the annealed condition. I can only assume that the thickness of the plate is sufficient to cause the weld to be in a normalised condition, rather than slow-cooled annealed, although my understanding was previously that for austenitic steels this should make no difference.
Our local fabrication shop did the cutting out of the 5mm SS sheet in a huge guillotine; the loop is two plug welds into the flat base as I might suspend a block and tackle from it for MOB use.
I've hurriedly put together a couple of stainless luff groove slides. Very rough stuff, I know, even after I have had a go with a linishing pad and angle grinder.....
My normal metal files don't make much impression on smoothing out the welds and sharp edges.
Can some kind techy recommend a good make of files for stainless please ?
Well, a lot of this has gone right over my head but I think I'd be right in saying:
Cold working (bending, sawing, machining) will work harden 316 and 304.
Welding will work harden 316 and 304
Cold working 316 will magnetize it.
One last question. Often when you buy hose clamps the band is S/S but the screw is slightly magnetic. I challenged a supplier saying the clamp was not all S/S as stated on the package because the screw was (weakly) magnetic: he insisted they were all S/S. [/I]
Thanks Vyx
I'm going to use 2X "T" Bolt clamps on all underwater fittings. anyway. But I really don"t want to hacksaw clamps off because the screws have rusted.
