oldbilbo
The top end of my 1" rudder post is formed into a 'male square taper'....
Onto it fits a block of s/s which has a 'female square taper', mating with that above. The nut is to retain this in place.
Welded onto the rear/side of this block is a short horizontal tube which takes a through-bolt, permitting the end of the tiller to secure to the above assembly.
I'd like to have the above s/s block reproduced, using the original as a template. How involved, please, would be the cutting of the 'female square taper'....? What sort of gear is necessary?
