halyardmonkey.
Hiya all,
I have a little problem with an outboard that I could really do with some ideas about.
It's a 4hp outboard mercury two stroke that has some strange behavioral problems..... Will start easily from cold and will idle easily, however, once you put it into gear it will cut out unless you keep the revs up- If you have succeeded in motoring a little the engine will idle in gear usually but not always.
However the engine will cut out usually just off idle to around 1/4 throttle when in gear and struggle to pass through this faze into cleaner running..... If when you reduce the throttle the engine will cut out.....
The engine has on two occasions been into the drink... But has always been dragged out quickly and has worked afterwards....
Have checked the plug and it is fine, cleaned the carburetor but admitted could not get the jets out.... Perhaps this is a clue???? Have taken the head off to check the condition of the bore which seems fine...... The engine does have a slightly gravelly sound to it though.....
It may well have more than one problem.
So any ideas or thoughts would be great!!!!
