bugsboat
New Member
I am having a hard time moving the shifter from neutral to forward on this little engine. Can anyone shed some light on what could be the problem? The engine starts and runs great.
you do not need to remove the gearbox or linkages but you will have to remove the powerhead. I did the same job on a 3.5 4 stroke Mercury last month. Plenty of heat and oil around the leg casting where the lever passes through usually does the trick. Dont force it or it will breakIf you would like to let me know a few more details of what model I may be able to help. If you are comfortable with a bit of fiddling about, the first thing is to take out the gearbox side by loosening the gear shift rod at the lower end and see if that makes the problem go away, caution though, it can take some setting up after disconnecting so don’t go mad. most gear shifts need the power head to be removed for a full fix so the next thing would be to try a bush fix. In order to do this you will need to remove the lower unit as if you were accessing the water pump, if you’re happy to do that sort of thing yourself let me know, if not you are likely best to chuck it into a local marine engineers and have it fixed. A lot of times the problem is at the top of the gear shift shat where it gets corroded and covered in crud and the full fix requires power head removal. The bush fix does work thoug
Heat ... boiling water to begin with then a hot air gun.Hmmm I have the same problem with my Tohatsu 2T, but the lever is completely seized. It'll break if I try any harder, and I've got everything disconnected so it's 100% the plastic lever itself.
Any bright ideas?
