joliette
I'm just starting to look at wiring up my power trim for two drives. I have a Quicksilver dual throttle control, which has the two trim switches built into one of the throttle levers. I have identified the 5 wires relating to port up / down, stbd. up / down and common. However, these wires are quite a light gauge compared with the wiring in the power trim pumps and looms, so I am concerned about connecting them directly to the trim pumps ...
Investigations so far have revealed a Mercruiser Dual Trim Control Panel, containing a couple of relays connected to a trim switch panel (that I do not need as I have the switches at the throttle). This suggests to me that I ought to install a similar relay set up with my Quicksilver dual throttle ... Is that the correct the way to go about it?
