Mike k
just been to Antibes, Nice ,Cannes Monaco- why do boats moor stern in and anchors out front? Would have thought with the money down there that pontoons would be a nailed on certainty.
The front is a bow line secured to a large chain on the bottom of the marina no an anchor.
Pontoons cost and take up mooring space and are not needed in the med as it is not tidal.
Med mooring is simpler than pontoons in any event. It’s always the same with no faf of springs , fender heights etc
Thanks so its a pick up buoy arrangement? Fendering looked a major issue to me between boats.
The front line is usually attached to the concrete quay, so you reverse in, put the stern lines on, then pick up the front line from the quay and walk it down to the front,pull it tight and tie it on a cleat. On the home mooring most people have a permanent loop in the front and rear lines at the correct length to save faffing around getting the length correct and tieing onto the cleat correctly. With a permanent loop you Just put the loop over/through the cleats and your done.
Touching the neighbours boat on the way in/out is a given on smaller boats at least, the spaces are too tight to not touch, no big deal, fenders roll along the boat allowing it to happen without damage.
You do need to be correctly fendered ,but that's not hard to figure out.
Also, with posher marinas if you call them when your coming back into the marina they will head to your berth and take your lines, fender off, etc. Some even send a rib round to give you a push if you get it wrong!
I did however get caught out as I didn't realise that there were two ground lines that were both attached to a single lazy line. I think the Marineros thought I was simple or something.
I heard folks calling it either "bow" or "ground" line.what's the correct name for the thicker line that you tie off to your cleat?
Also, is there a rule of thumb for when you should use fairleads as opposed to trying the line directly to your forward cleats?
Wrong question. The right one is, "why not"?why do boats moor stern in and anchors out front?
Can someone confirm the correct names for the lines?
Is the lazy line the section of lighter rope that goes from the quay to the main line that's attached to the chain? If so, what's the correct name for the thicker line that you tie off to your cleat?
Bear in mind if it is thick it is probably long and defiantly heavy so put it on the winch !
