TonyR123
i have marked both bow and stern lines are marked for me. I tend to get the bow lines up to its marker and then reverse back. no winch needed on the bow or any strength of note to tie the line up.
What winch?!
Your anchor winch will allow you to disengage the clutch and winch the bow line. I do it 2-3 times a season when on long thick lines. Life saver or the boat goes sideways. The sag in the lines is huge
Coming from pontoons in Scotland, I thought i would hate it, but it's actually not bad at all.
Here is a great how to explanation.
All agreed, but relying on a fast assurance of the bow line (or on the b/t capacity to contrast Xwind) is a bit risky.However if we have a cross wind & 'time is of the essence', we put only one stern line first (same side as the lazy line) and quickly take up the lazy line forward, so we have at least got some control over the bow, using the bow thruster to assist the crew to pull up one of the bow lines. Then sort out the other stern & bow lines in our own time....
Excellent video
Sorry, I don't agree with those suggesting to use the anchor windlass.
IMO, Nick's method is the best way.
The process is really easy if you are returning to a previously occupied berth if you have marked the bow (lazy lines) before you left.
I usually wrap some electrical tape round them before we leave.
Simply (as in the video) loosely attach stern lines and then it is easy to attach the bow line at the previously marked point because it doesn't have any load on it.
Let the boat drift forward.
Then winch, motor (yuk) or manually pull the boat back using the stern lines.
As I say - just like in the video.
The problem comes if you haven't been to a berth before and the lazy lines aren't marked for your boat.
For me, I modify the above approach by doing it in two steps.
Reverse back as before and attach your stern lines .
Now leave them loose - and I mean loose - even let them drop in the water.
Now take the lazy line forward the boat will drift a long way out - let it - in fact people will say "you are too far out" - ignore them.
Attach the lazy lines a long way out - the stern lines should still be loose but attached to the boat.
Lifting even the biggest lazy line rope is easy - there will not be any load on it - just its weight.
Now (with the lazy lines attached) pull back on the stern lines.
The boat should not get anywhere near the quay - people will now say "I told you so!!!" - still ignore them.
Now make an assessment of how far you need to go back.
Then simply let off that amount on the bow lazy lines.
Re-winch back in and you will be in the perfect position.
If you are staying for any length of time, mark the lazy lines so that it is easy next time.
It is all a bit harder if you have an empty space or spaces beside you but the process is the same.
In our case, SWMBO does all the lines whilst I keep the boat in the correct position.
Using the bluetooth headsets, as soon as she has got one of the lazy lines secured to the bow, I leave the helm and help.
But, we NEVER use the anchor windlass - the last thing we want is the anchor to launch itself in the middle of everything.
If you haven't got stern winches, just pull using ropes and cleats (pull against the cleat - don't pull the actual rope) or I have seen engines used to "pull back" (I wouldn't do that myself though).
When it’s really a strong beam wind and there is no boat next to you, it’s better to get one stern line on but to the opposite cleat. This crossed line will stop you from being blown over the lazy line (or too far from it, depending on the direction of the beam wind). Then get the lazy line (still prefer to call them slime line) to the bow and secure the rope (or chain). Even if you have a lot of slack, you can now rest and handle the lines at your leisure
