Yngmar
Looks line our PCV valve (#34) is blown and doesn't close anymore. I've found some oil in the hose connecting it to the air intake and around the valve, which is apparently a symptom for this. The engine is consuming more oil than it used to, although an oil change is due. I've removed it to inspect (also cleaned years of oily gunk out of the air intake mesh). As per Haynes manual, the valve should click when a vacuum is applied to the hose end. It does not, it just makes a sad feeping sound instead, so I assume it's dead. It's crimped shut and not servicable.
Volvo wants €121 for one (Part 859743 "Valve"), which I would obviously consider as a last resort only. The Perkins part number might be 2652851 "PCV Valve", but the only source I can find is one in the US (we're in Sicily).
Can you help identify the part and where to source it for less? On the bottom it says "AC" and "Made in Eng." and there's a difficult to read number stamped in that may be "3822G0" (the G could be a 6 and one of the 2s is very faint).
