MD2030 engine mounts
sailaboutvic
26 Jan 2004
Northern Europe
Volvo MD 2030
Probably some reading this have done the job before other have read how to do it but never have ,
Then there tho who are maybe thinking of doing it.
This posting is directed at them .
It’s a job in over 40 years of boat ownership I not done .
I read about it and it sound an easy job and is if there wasn’t a engine in the way .
Let me say from the start you really need two people one with child size hands .
I marked the foot print of each mount and measured the hight of each one ,
The plan was to fit the new ones how the old once came out , let me say now it didn’t work .
But before I get into that I needed to remove the old once’s .
Each mount is held in the engine bed with two bolts with locking nuts ,
To get to each nuts there a hole in the side of the engine bed to place the spanner in , here the problem , the holes are not in line with the nuts plus the engine sump doesn’t leave you much room to get a normal spanner in ,
You really need one with a bit of a kink in some of the holes ,
You also need very small hands to be able to remove the nuts and washer , child like hands , your mostly end up dropping the nuts or washer or both inside the engine bed resets,
I put rags in there to catch them but sod law there end up in the engine bed never to Be found again , luckily the nuts are mild steel and a magnet manage to find most of them but not after what seen hours moving the magnet back and fro on a string from one hole to the next.
In the end we only lost one of each .
You don’t need a jack as some people say who really never done the job them self just read about it ,
anyway there no way you could get a jack in there .
a long lump of wood is enough to lift he engine so you can block it .
The rear mount I remove the bracket from the engine , just three bolts .
The front I manage to get the engine high enough to slid them out.
Don’t ask how we manage to locat the nuts and washer back on , by luck more then anything.
I used tape on the washers to cover most of the hole so the tape would grab on the bolt thread ,
my wife squeezed how much of her hand in the hole balancing it on the tip of her finger push it back up the thread the tape kept it there ,
She probably drop each nut three or four times balancing it on the tip of her finger while I slowly turn the bolt for it to catch .
In the end after a lots of F words and hours we manage to finish it .
Lining up the engine was some thing else .
Although the mounts where in the Same place and hight the shaft was way out .
To get it to line up the front engine sat on the mounts not a good move .
Thanks to chrome Dome from here who send me a page from the MD 2003 Manuel which give reference to how the engine sit I set the mounts up to 85mm ( not the hight there where at ) from the top of the engine bed to the bottom of the engine mounts brackets as a starting point ,
This mean the shaft coupling was around 1 cm lower then the engine coupling this was about right when you think about the weight of the shaft ,
Lifting the shaft slightly match it nicely
From. There on it was easy to match up the gap in between both coupling with feeler gauge, adjusting front and back mounts a little .
This posting maybe long , but no where near how long the job took to do.
If I had to do it again I would hire a child for the day .
Why they couldn’t
( A )cut the holes where the nuts are on the engine bed only two was nearly in line , some where 2 cm away .
(B) cut four hole on each side instead of three
And (C) make the hole slightly bigger , for the F of me I can’t work it out what these so call professionals are thinking off .
let me say I nearly give up trying to do the job and paying someone .
Best of luck tho thinking of doing the job.
Thats the nature of boats. Just wait until you need to do something like remove the fuel tank and realise it was installed before the deck was added.
Yes I have done the engine mount job on a 2030 and it was a bit easier the way my engine compartment was but still a PITA. Mind you it was as nothing compared with replacing the toilet in my current boat, something that must have been installed by a ten fingered midget with no sense of smell.
Your difficulties were related to the boat design rather than the engine. Other installers (like me!) use coach screws or bolts into threaded inserts or captive nuts rather than bolts and inaccessible nuts. So well done for successfully dealing with a fundamental design flaw!
It wouldn’t had been half as bad if only they cut the access hold by the bolts and made then bigger .
20 years ago I had to cut a steel tank out of a locker on my then Moody 336 .
so I know very well what it’s like . :)
not a nice job
