Mark L
Hi, looking for advice on an issue that I've been having with a (new to me) MD2030-D, the first volvo penta engine that I have owned.
First time on the new boat, taking her on leg 1 of the trip from the south coast up to Scotland. Initially no issues whatsoever with the engine, including about 7 hours under engine when the wind dropped off on Sunday night. However, 4 or 5 hours later when I started the engine to come into the marina, the high temperature alarm went off. On later inspection, I noticed that the coolant was low. Topping the coolant up solved the temperature issue, but the coolant continued to drop substantially when the engine was running. I would estimate a loss of around a litre per hour, but no visible coolant under the engine or in the calorifier compartment. No evidence of water in the engine oil, and the engine continued to run fine if topped up. Coolant does not drop when engine is off.
Possibly related: I initially thought that the raw water flow was low and the exhaust sounded a little dry. I pumped some air down the inlet pipe and it felt like there may have been a slight blockage before I could hear bubbles coming through. May have been my imagination though, and this made no difference to the coolant leak. Impeller and strainer are both fine.
Reading a bit online about the cooling system on these engines, my first thought is that it could be the rubber end caps that seal the inlet, and separate the FW and SW sides of the system, but I thought I would see if any other Volvo Penta owners had experienced similar or had any other suggestions on what might be causing this.
Thanks!
Thanks!
