VicS
The cap without the rubber gasket immediately under the flat head of the cap must have lost its gasket in transit. It cannot have been made like that as it won't work ..... when the pressure builds up coolant will push past the first gasket and probably come out from under the cap. When it cools it will suck air in from the outside rather than suck coolant in from the expansion tank so the level of coolant in the block will get lower and lower whilst the expansion tank stays full.
Richard
I think you are wrong
He has not mentioned an expansion tank. I think you will find that there is just a simple "overflow " connection to the filler neck directing any escaping coolant into the bilges (#14) ... at least that's what the basic parts diagrams show. If that is so a second gasket under the top of the cap is not necessary.
If an expansion tank is fitted it's a whole different set up most easily explained with the diagram from the parts list:
if the neck is still securely attached I would ensure the coolant level is below the filler and then use wet and dry to sand off all the paint around the bottom the the neck and the adjacent top of the H/E and then degrease it with meths or similar. Then apply a good fillet of JB Weld or similar right around the neck. You could also apply a "rolled sausage" of Milliput or similar as this will be even easier although you will need a coarser wet and dry as a rougher surface will be required to ensure a good seal.
Richard
I think I would try a metal filled epoxy such as J-B weld original http://www.jb-weld.co.uk/j-b-weld-epoxy-adhesive/j-b-weld-original-epoxy-adhesive
