R
robmann
Guest
Re building head assy.on the MD11C. I think this is one for vic. On the valve guides only of the inlet valve there is a rubber seal. The sevice kit supplies four of the seals do i need to fit them also to the exhaust valves as well as the inlet valves. Also the injectors go into the housing about a inch then go very tight should i just tap this home very carefully.
