StefanSG
Hi I have an MD11C which I reconditioned about 2 years ago with new rings, gaskets, deglazed liners, serviced injectors valve seals etc. The engine starts readily from cold. It has developed an issue where after running for about 45 minutes the revs start hunting, for a few minutes, and then the engine stalls and won’t restart. New fuel
tank, fresh inspected fuel, 2 brand new filters. If I bleed the fuel pump with the manual lift pump, I get bubbles and air for 20 seconds, after that the engine will instantly restart, and will run fine at constant 700 rpm but then stall again after 15 minutes. Where should I start looking for the problem or leak ? All of the fuel hoses were replaced during the refit and they are proper swaged expensive ones. The oil filter has a pressure equaliser fitted on the top which I notice many MD11c’s only have a bolt. Most washers and seals are new and tight. I have bought a new set of seals for the vacuum side of the supply and will redo the seals on the CAV primary fuel filter (glass bowl type) and the bleed screw seal on the secondary filter housing. Manual lift pump appears to work fine.
Hoping someone can advise. Running out of season and very frustrated. (One thing that wasn’t reconditioned during refit was the high pressure pump so if that’s a likely culprit I can get that serviced locally)
Many thanks in advance.
