seaesta
I have replaced the impeller on my Volvo MD1 water pump which is made by Jabsco. The water throughput seems to take a long time to get going and be less volume than before. I have checked the output when hand cranking the engine by disconnecting the water inlet flexible pipe and watching the water output - which seemed to be OK. I wondered if there is some sort of thermostat or blockage in the head but when I blew through the system by mouth the flow seemed to be quite easy. The pump itself seems to be well worn (37 years of debris laden water). Any advice on
- how to test
- how much for a new pump and who can supply
- how hard are they to fit in situ (not bad access through a hatch).
Martin
- how to test
Martin
