rogerthebodger
On a boat, many small engine air intakes are baffle types at the inlet and would be difficult to seal e.g. my Perkins 4236 has a mushroom air inlet filled with a filter material, so shoving a rag over it would not be effective nor could it have a bung inserted without removal of the filter element from the manifold.
This is the reason I considered fitting a valve under the inlet filter that could be moved into a closed position without removing the air filter.
If could also be used as a anti theft device preventing any possibility of starting the engine without opening the valve
