Laminar Flow
Agree.Nope.
Definitely spinning unless 2 blade hidden behind a long keel.
Without any maths just think about this, if the prop fixed offers less resistance than spinning, why does it spin?
Everything I have ever read, including testing done in a tank, indicates that a prop left to freewheel reduces resistance by 40%. I'm pretty sure this argument has been resolved in all finality.
My last boat had twin engines with 3bladed fixed props and letting them spin under sail certainly made an appreciable difference. On our current vessel we can, as this is a function of the gearbox, let our prop spin; there is very little discernible noise and certainly none that bothers us.
In regards to Dream believer's observations: The faster a boat's relative speed, the less the loss in speed due to the prop in spite of the increase in resistance. This is because the Boat's overall resistance is considerably greater at higher speeds. Conversely, the loss in speed at slower velocities is the greatest.
At a relative speed of 0.9 speed loss is: for a spinning 3 blade 8%, feathering or 2 blade is 4% and a folder is 1%
At a relative speed of 1.1 the loss is: 3 blade - 6%, feathering or 2 blade about 3% and folder sub 1%.
At hull speed: 3 blade 4%, feathering or 2 blade 2% and folder again sub 1%.
(data from "Motorsegler", Donat, Delius&Klasing)
For us, with a spinning 3 blade ,this would would mean a loss of 0.4 kts at a relative speed of 0.9 (4.8kts). If we locked the prop we would lose 0.7kts. At hull speed (7.12kts), I lose 0.28kts (spinning) or 0.4kts if locked.
If I were to invest in a feathering model (we do not have room for a folder) I could, at lower speeds, gain 0.2 kts, at hull speed 0.14 kts.
For all the arguments concerning prop drag, I have yet to see any analysis of the resistance caused by exposed shafts, p-brackets or the blunt ended shaft housings seen on some AWB, regardless of what type of propellor they are using.
