BrianH
http://www.ybw.com/forums/showthread.php?440525-AIS&p=5455186#post5455186In Richards case, he is surrounded by mountainous islands, the mountains being the reason he sees vessels "around corners".
The error correction being discussed here, from post 48, does just that.
" as the digital error correction reconstructs the missing data "
a) AIS is, like VHF, line of sight (plus the usual addition for atmospheric refraction). This is a well documented scientific fact.
YHowever, it does not cover the signal transmission/receive decoding layers, which I had always assumed contained some level of cyclical redundancy check (CRC) code. Difficult to access due to (as you mention) propriety restrictions (that damned Swede again) but I distinctly recollect that in the AIS specifications are references to such in one of the data link layers.
And wrong....
My points were simple.
And wrong.
Not sure what Mike was referring to there Richard.
The receive-only type do no switching: they send the signal from the antenna to both receivers. To switch they would have to analyze every incoming signal and decide whether it was voice, DSC data or AIS data and route accordingly.
Do they not do some switching to achieve sufficient isolation between VHF tx and AIS Rx?
I have, at last, found the AIS transceiver specification, it is an ITU document: ITU-R M.1371-1, Annex 2.Your link is indeed an excellent reference to AIS message formats (and as such it resides as a prime AIS reference in my bookmarks). However, it does not cover the signal transmission/receive decoding layers, which I had always assumed contained some level of cyclical redundancy check (CRC) code. Difficult to access due to (as you mention) propriety restrictions (that damned Swede again) but I distinctly recollect that in the AIS specifications are references to such in one of the data link layers.
Back in my comms programming days, the normal application of CRC for error detection was to have the receiver request the sender to repeat the transmission but, of course, with AIS the transmission is one way and it can only recognise a data error and discard the message. In practical terms this is no big deal, the next one will be along shortly. I am aware of CRC algorithms that can reconstruct the data but would not expect such an overhead in AIS message packet processing layers due to that frequency of repetition.
