LadyJessie
For a long time, I have thought that the colreg of having an anchor light visible at 2 miles is meaningless for yachts, The colregs are clearly written for commercial shipping where this requirement is very reasonable; big ships need this distance to react and change course. But a yacht very seldom (if ever) anchor close to shipping lanes where this requirement could have any meaningful effect. I also believe that the colregs are written with the understanding that you must also use your common sense. Time to apply that.
Hence, I think that the present practice of placing anchor lights at the masthead is very dumb and dangerous. Yachts typically moor in small secluded coves and bays where a visibility of 2 miles off is totally meaningless. What you need for a yacht is an anchor light that is visible 20-100 meters away to other yachts trying to anchor in the same cove. Most of the time, a masthead light is very inefficient or even invisible for this task. A dangerous practice.
This fact was dramatically drawn home to me yesterday when I was anchored in a bay on Symi island in Greece. This bay is known for its very fierce gusts around sundown. That is usually not a problem, this fact is very clearly pointed out in the pilot books of this area and if you have ensured that your anchor is dug in it is just a windy experience but something you ride out easily. Just before sunset, I got a charter mobo dropping his anchor in front of me. When the normal gusts came up, it quickly was obvious that he hadn't dug his anchor in so he was wrapped around my bow. Adding to this problem, he turned out to be an i***t who had no idea what to do. Instead of reversing off my chain, he went forward and managed to wrap his chain around mine. When finally understanding that he needed to retrieve his chain; he also pulled up mine. My personal opinion is that public flogging is a much too lenient punishment for this sort of offence.
So; I had to re-anchor in 30 kts of wind gusts in the dark in a crowded anchorage. This is the Med so as in all other warm weather areas you normally have cockpit bimini covers and sometimes even extended cockpit covers. It had been a hot day so I had both. This means that as you move around the anchorage, you cannot see lights 15-30 meters up in the air; you are looking at cockpit level at short distance. While trying to line my anchor up into the wind in the dark, I did notice that I narrowly missed two yachts that was only visible to me at about 5 meters off when I saw their white hull reflecting off other lights in the bay (but they had their colreg masthead lights on so I would have seen them 2 miles off, doh...). The next morning I was chocked to notice that I had anchored close to a third yacht that I hadn't even noticed (again with the regulation masthead light on).
In summary; I have found that the practice of having a running light hanging over you boom or even a garden light type solar light mounted on the transom is significantly more efficient in avoiding collisions while anchoring in normal small yacht places than the traditional tall mast head lights.
Imho, colregs anchor light rules make sense for commercial shipping, but could be dangerous to apply for yachts in small anchorages. Is it time for an update?
