wavelet
Found stainless steel tubing to replace the twin steel posts beneath the mast tabernakel. Reason to change is clutter of twin posts and therefore preference for central pole in direct line with the mast as more elegant and clearing space, with polished stainless steel looking cleaner than painted steel in the cabin.
Advice on strength needed as tube is slightly thinner than anticipated. I had decided a 75mm diameter stainless steel tube of wall thickness 4 or 5 mm would be ample. The boat weighs two and a half tons, she is a Folkdancer 27 designed by Fred Parker. The tube I found has a wall thickness of 2mm (75mm) and I do not quite feel it is strong enough to take the compression of the mast. I was imagining a force of up to three tons coming through the deck from the mast, so estimated a four ton minimum compression resistance of the new tube.
Is the 2mm wall thickness a bit thin? Must I search for a heavier tube?
