Mast storage
Samoddie
5 Oct 2021
Hoping to glean some wisdom.... I have left my trailer sailer in a yard, a long long way from my house. Mast stored horizontally on push pit and pulpit rails. Sadly a bit of clearance between hatch garage and line of mast. Do Ineed to worry about leaving my alloy mast stored thus for months on end?.
Chiara’s slave
14 Apr 2022
Western Solent
As far as I know, you’ll be fine as long as ‘a long way’ isn’t on Venus. Alloy creeps at high temperatures, 250 odd degrees C, but not at temperatures humans can stand.
William_H
28 Jul 2003
West Australia
I store mine in the same way for 5 months every year. (now about 25years this mast) Yes there is a noticeable droop in the middle of the mast. If you are worried then a bit of packing under the middle to make it straight, but I would not worry. ol'will
Refueler
13 Sep 2008
Far away from hooray henrys
Many of us have this situation ..... it is true that a mast will 'droop' slightly in the middle, but once stepped and setup - should be ok.
If a 'prop' can be placed under the mid section - then it can do no harm.
I have a heavy mast for my 'small' boat but so far do not prop mid section ashore ....
