conks01
Hi,
I'm looking for the best advice here as I have an issue and I'm over-complicating things as normal.
So, I'm looking to return all lines to the cockpit including the main halyard. Prior to this I was going forward to hoist and the new mainsail whilst stored in a stack pack, went up fine albeit I had to feed in the last 4 slides by hand as for whatever reason (& probably when the new sails were made they were not sized correctly for the sail track?) there's not enough room for them to sit in the existing mast sail track.
I need to extend the track therefore by approx 265mm. The track is 4mm wide.
I've thought about fixing to alu' angled strips either side to form the 4mm gap/track extension but this won't work due to the lip/height of opening above (the gap is also 22mm wide). See pics below.
I'm wondering if anyone else has had this issue and had a workable solution? I was thinking whether I could fit a length of ply (strip) within the 22mm gap and then fix to that with an Allen (or similar) sail track extension but can't see this working either.
As I say I'm sure I'm over-complicating this!
Any guidance greatly appreciated.
Thanks.
Thanks.
