William_H
The subject often comes up. I was invited to join the fun this morning on Brian's new to him boat the Joly Roger in moving it from Fremantle Sailing Club to East Fremantle Yacht Club. This involves traversing under 3 bridges hence mast lowering.
Jolly Roger is a Viking 30 ft mast head rig. The deck stepped mast has a pivot.
The cap shrouds go to chain plates via purpose built solid extensions seen in second photo which are braced forward with rope to ensure the cap shroud pivots in a line with mast pivot hence stays stay tight as mast pivots down.
2 spinnacker poles were used as brace for the 5 purchase tackle going to a jib halyard firmly cleated. as seen in first pix. The poles pivot in rings welded to flat plate bolted to deck aprox. ajacent to the mast
The mast was rested in an A frame at the transom which in our case could have been a metre higher.
The boom was removed. The tackle tightened until forestay was slack enough to remove the clevis pin a the deck. A tug on the backstay and down she came no probs.
It was hauled up again barely needing the aid of a winch. Less than 5 purchase and using the winch would have been better. (faster)
All done while under way.
Granted it is a little more difficult to remove the mast to lay on the deck. That takes a bit more muscle from this stage. olewill
