Mast Cleaning
Achilles
10 Mar 2002
Costa Blanca
I'm in the fortunate (or unfortunate) position of having my mast down and it's definitely in need of a good clean. I'm hoping some of you have practical experience of cleaning anodised aluminium masts and can pass on your knowledge. I think this one is past the soap and water stage, last time it was down I used Polytrol with the coloured scouring pads you get in Asda. This was partially successful but I really think it needs some kind of non etching acid to do the job properly.
All advice appreciated.
Althorne
13 Oct 2003
London
You should have left it up and used a small boy like the 19th century chimney sweeps did! Would have been a lot less trouble. Just a crust of bread every now and then and stow it in the lazarette until needed again.
<hr width=100% size=1><A target="_blank" HREF=http://colvicownersclub.mysite.wanadoo-members.co.uk>http://colvicownersclub.mysite.wanadoo-members.co.uk</A>
SteveGorst
10 Dec 2002
CONWY
When I posted this question earlier in the season I was advised to use T cut. It's done a good job on my mast removing some black marks. While I was at it I used it to polish up the compass which had become a bit fogged up; it came up like new.
Hope this helps
Steve
<hr width=100% size=1><A target="_blank" HREF=http://www.nwcc.info>North Wales Cruising Club</A>
Plan_B
28 Jul 2003
S.Devon
Give Andy at Allspars (QAB Plymouth) a call, he gave me a little tin of fluid they use to clean aircraft with. We used the stuff and couldn't really see the difference at the time - now the vessels back on its berth it looks really shiny. He also said don't use any abrasives as the anodising could be damaged.
Dave D
