Fantasie 19
Peel it off as soon as you have finished.
+1
Masking tape is cheap - I just mask it again if I'm going to put a second layer on...
I will be re-antifouling my boat next month.
Last year - the worst job was removing the masking tape from the waterline.
After a couple of days in the hot portuguese sun it was baked on. Parts of it needed removing with acetone and it was a long slow job.
Can anyone recommend a good masking tape so that I can take some decent stuff out with me and make the job this year a bit easier?
Thanks in advance.![]()
The 'Blue Stuff' that everyone is refering to is known as 'low tack' and even low tack if left on can be a problem, i never leave any tape on for longer than 1 hour after i have finished painting.
I left my heads port light open a couple of seasons ago and a friendly neighbour taped a plastic bag over it to keep the rain out, I am still trying to get some of the masking tape off!
Going to maybe try the yellow frog tomorror
Considering this is for the waterline I would expect the stickyness to come off in a day or so sailing anyway so I can't imagine it's worth that expense.
Pull it back at 180° (back on itself) to avoid lifting the coating.
...The 3434B is designed to go round corners too, it's stretchy. All primarily for automotive trade --except long-mask which is for home DIY hence why found in B&Q....
The 3M 3434B shouldn't be left on for any significant period of time - take it off sooner rather than later, as the adhesive will cure and stick like you know what to the substrate, especially in UV / sunshine. The scotch version is different - officially called long mask and is designed with a different type of adhesive not to cure and leave adhesive residue after longer periods of time - but has it's limits too - and scotch branded automotive product is normally US markets only.
The plastic tapes referred to are for fine line / fine edge results.
There are other versions of the 3434B that offer lower tack and similar stretch properties, but are lighter backings so perhaps not as strong in an outdoors environment.
I must declare my association with 3M masking products -I work for them, but happy to offer technical advise as needed!
I find that the most time consuming part is applying the masking tape - certainly more than 10 minutes - so I use good quality tape and leave it on for all coats before removing. The plastic tape gives a sharper edge and comes off well but I also like Frog Tape which is very strong. I've not had good results with Pound Store stuff in general. The masking tape is a very small part of the cost of antifouling, or indeed any painting, so it doesn't really matter if it's one pound a roll or five.+1
