siwhi
We have a Marlec Rutland 914i which came with the boat we bought in January and was not working at that time. It is plugged into a Marlec HRDi along with several Siemens solar panels which work well. I changed the brushes on the 914i and it supplied power intermittently for a few weeks, but now doesn't anymore. I can't find the problem, the connections seem OK, however the unit seems to have been taken down and worked on a number of times and is far from new; there is a large box of used spares on board. Quite possibly a connection or wiring issue with an open circuit (but the cabling from the pole to the controller is sound - tested by multimeter) but probably not worth further investigation, or servicing each month.
My question is what options do we have: replace with a new 914i, or are there any alternatives which ideally will plug straight into the HRDi and even better, use the existing support pole and cabling? Is this possible? Marlec say the new 1200 fits the pole but would require a new controller.
Thanks for any suggestions!
